wjmeyer
#1 Posted : Tuesday, December 15, 2009 6:26:49 PM(UTC)
wjmeyer
The drum will spin but the dryer will not heat up. The drum light also does not light up. These problems occured at the same time. I have tried tripping the breaker and it did nothing. When I hold down the door switch and turn on the dryer I can see the drum spinning. When I let go of the switch the light comes on and goes off again quickly like flipping a light switch. What might be the problem?
sidfink43
#2 Posted : Thursday, December 17, 2009 5:35:29 PM(UTC)
sidfink43
You are going to have to open it up and check the wiring that goes to the door light and thermal fuse/thermostat devices. You my just have a loose connection which is causing the problem, and if that loose connection is in the circuit that goes to the thermostat it can cause the dryer not to heat.
Inside the console you should find a wiring diagram which will help you trace the circuits you need to check.
If that does not work, check the thermostats for continuity.
dryer won't heat up (Dryer Repair)
by dnell 8/26/2014 7:21:16 PM(UTC)
LG gas dryer won't heat up (Dryer Repair)
by Farmer85 10/2/2013 9:21:16 AM(UTC)
GE electric dryer won't heat up (Dryer Repair)
by jrogers 7/4/2013 11:55:26 AM(UTC)
by Teresay 6/11/2013 6:40:08 PM(UTC)
Dryer won't heat up (Dryer Repair)
by ford4wd08 6/11/2013 9:42:58 AM(UTC)
frigidaire dryer won't heat up (Dryer Repair)
by wilde1537 5/6/2013 10:27:04 AM(UTC)
Whirlpool Duet Gas Dryer Won't Heat Up (Dryer Repair)
by evanr99 2/1/2013 6:16:21 PM(UTC)
Maytag Electric Dryer won't heat up (Dryer Repair)
by rajpat25 7/7/2012 12:56:23 PM(UTC)
by d burns 5/17/2012 12:18:14 PM(UTC)
Bosch Dryer won't heat up (Dryer Repair)
by tericribb 3/18/2012 10:05:30 AM(UTC)
Whirlpool Thin Twin Washer Dryer Combo, Dryer won't heat up (Dryer Repair)
by NVChickey 2/25/2012 10:50:02 PM(UTC)
Dryer won't heat up to dry clothes (Dryer Repair)
by tdeai 7/21/2011 3:55:49 PM(UTC)
by krisr 2/8/2011 2:52:24 PM(UTC)
Heating Element on Roper Dryer won't heat up (Dryer Repair)
by c grass 11/23/2010 5:26:01 AM(UTC)
by WW47 7/29/2010 1:07:03 PM(UTC)
