The light of the refrigerator and freezer is working but the refrigerator and the freezer is not cooling. please i need help. thanks.
Please check your model number, all MGD's come up as a gas dryer.
Check to see if the compressor is running. It should be warm and vibrating. If not try setting the temperature to a colder setiing. Does the compresoor start up? Also are the compressor fan and evaporator fan running? If not you may be stuck in a defrost cycle. |
THIS FORUM IS DEAD!!!!!!! |
