Gene, This is Charles, You are right, the fan is not working and the coil is frosted over, So I turned the unit off for now. What do you recommend is the the fan unit bad? Or do I have bigger problems.... Thanks in advance:rolleyes: .
Gene, P. S. The meat control lever is off. Do you think it is the Fan motor. If so is that the only part to replace?
Gene, I just wanted to thank you for your advice. I ordered a new damper assembly based on your advice, and replaced it Friday, and haven't had any issues with it since then. Based on previous experience, I think I would know if that wasn't the answer by now. Saved me a $$$ service call, which would have definitely impacted the holidays.
Thanks again, and happy holidays!
Charles, Sorry for the delay. If the fan is not blocked with snow, then it has to be replaced. It is recommended by GE pros and proven with many repairs that the fan motor has to be replaced together with the main control board (on the back of the refrigerator). Hopefully there is nothing wrong with the defrost system parts and excessive snow is result of the broken fan motor. - The evaporator fan motor (with thermistor) Part number: AP3191003
Originally Posted by: jaxcarlson  Gene, I just wanted to thank you for your advice. I ordered a new damper assembly based on your advice, and replaced it Friday, and haven't had any issues with it since then. Based on previous experience, I think I would know if that wasn't the answer by now. Saved me a $$$ service call, which would have definitely impacted the holidays.
Thanks again, and happy holidays! You are welcome. I'm glad you were able to fix it. Happy Holidays to you as well. Gene.
Gene hop you are having a happy holiday. Thanks for the help I will work on it when I get back to Georgia, I am currently in San Diego for the holidays. I will post an update in mid Jan 2010. Thanks Again:)
Charles
:) Gene,
Got back to Georgia 2 weeks ago, had to wait for the two parts, received them and installed them, (the motor and circut board), It is working fine, Thanks for the help I really want to thank you for helping me.
Charles Neighbors:)
You are welcome Charles. I'm glad you were able to fix it.
