3 Pages<123
Charles Neighbors
#21 Posted : Thursday, December 17, 2009 3:57:12 AM(UTC)
Charles Neighbors
Gene, This is Charles, You are right, the fan is not working and the coil is frosted over, So I turned the unit off for now. What do you recommend is the the fan unit bad? Or do I have bigger problems.... Thanks in advance:rolleyes: .
Charles Neighbors
#22 Posted : Thursday, December 17, 2009 3:59:24 AM(UTC)
Charles Neighbors
Gene, P. S. The meat control lever is off. Do you think it is the Fan motor. If so is that the only part to replace?
jaxcarlson
#23 Posted : Monday, December 21, 2009 11:56:16 AM(UTC)
jaxcarlson
Gene,
I just wanted to thank you for your advice. I ordered a new damper assembly based on your advice, and replaced it Friday, and haven't had any issues with it since then. Based on previous experience, I think I would know if that wasn't the answer by now. Saved me a $$$ service call, which would have definitely impacted the holidays.
Thanks again, and happy holidays!
#24 Posted : Monday, December 21, 2009 4:09:16 PM(UTC)
Charles,
Sorry for the delay. If the fan is not blocked with snow, then it has to be replaced. It is recommended by GE pros and proven with many repairs that the fan motor has to be replaced together with the main control board (on the back of the refrigerator). Hopefully there is nothing wrong with the defrost system parts and excessive snow is result of the broken fan motor.
- The evaporator fan motor (with thermistor) Part number: AP3191003
- The main control board Part number: AP4436216
#25 Posted : Monday, December 21, 2009 4:10:30 PM(UTC)
Originally Posted by: jaxcarlson Go to Quoted Post
Gene,
You are welcome. I'm glad you were able to fix it.
Happy Holidays to you as well.
Charles Neighbors
#26 Posted : Friday, December 25, 2009 11:01:51 PM(UTC)
Charles Neighbors
Gene hop you are having a happy holiday. Thanks for the help I will work on it when I get back to Georgia, I am currently in San Diego for the holidays. I will post an update in mid Jan 2010. Thanks Again:)
Charles
Charles Neighbors
#27 Posted : Saturday, January 30, 2010 11:10:16 PM(UTC)
Charles Neighbors
:) Gene,
Got back to Georgia 2 weeks ago, had to wait for the two parts, received them and installed them, (the motor and circut board), It is working fine, Thanks for the help I really want to thank you for helping me.
Charles Neighbors:)
#28 Posted : Friday, February 5, 2010 12:33:23 PM(UTC)
You are welcome Charles. I'm glad you were able to fix it.
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
GE side by side turns on only when I disconnect J4 plug (Refrigerator & Freezer Repair)
by PandaTaco 1/11/2024 10:04:34 AM(UTC)
GE side by side water and ice not working (General Talk)
by Guest 10/8/2022 6:17:31 AM(UTC)
GE Side by side fridge; control panel blank; not cooling (Refrigerator & Freezer Repair)
by peteror 3/20/2022 10:14:32 PM(UTC)
GE side by side PSS26SGPA SS (Refrigerator & Freezer Repair)
by Guest 1/23/2022 3:19:31 AM(UTC)
GE side by side clicks once by compressor then once on board. (Refrigerator & Freezer Repair)
by Schaanman 1/23/2022 2:03:33 AM(UTC)
GE side by side model GSS25KSTASS ice maker auger continues to run (Refrigerator & Freezer Repair)
by RodneyS 5/30/2021 2:59:27 PM(UTC)
GE Side by Side Freezer 25 degrees warmer than set-point (Refrigerator & Freezer Repair)
by reese600 1/21/2021 11:39:19 AM(UTC)
GE side by side starts and stops (Refrigerator & Freezer Repair)
by SethL 12/19/2020 6:58:00 AM(UTC)
GE Side by Side - Water/Ice Dispense (Refrigerator & Freezer Repair)
by USS Pogy 11/5/2020 4:08:04 AM(UTC)
GE Side by side GSHS6LGBBHSS (Refrigerator & Freezer Repair)
by Ksutherland 5/16/2020 10:05:38 AM(UTC)
GE side by side refregator does not start (Refrigerator & Freezer Repair)
by patel_bhavesh100 9/12/2019 5:32:28 AM(UTC)
GE side by side, uneven cooling (Refrigerator & Freezer Repair)
by GLMace 2/28/2019 2:46:16 PM(UTC)
GE Side by Side Thermistor Locations (Refrigerator & Freezer Repair)
by AlkiRich 1/3/2019 9:31:00 PM(UTC)
GE side by side, sporadic water and ice dispensing (Refrigerator & Freezer Repair)
by Ramski00 11/25/2018 12:13:04 PM(UTC)
3 Pages<123
