ekuntz
#1 Posted : 15 years ago
ekuntz
I have a Magtag model number MGR6772BDS. The top oven will not bake or broil. I think it is the ignitors, but I dont want to replace both if I only need to replace one. Any answers?
boyzbad
#2 Posted : 15 years ago
boyzbad
I have the same problem. The bottom oven works fine as well as the burners. The display pad is working fine also. The ignitors in the top oven don't appear to be broken. Do I just turn the top oven on bake or broil and check ti see iif there is voltage going to them??
Maytag Gemini oven won't heat (Oven Repair (including Ranges and Cooktops))
by jmatters 9 years ago
Maytag Gemini Oven wont heat (Oven Repair (including Ranges and Cooktops))
by Stevewk 12 years ago
Maytag gemini oven (Oven Repair (including Ranges and Cooktops))
by wendieww 14 years ago
Maytag Gemini oven is not heating up (Oven Repair (including Ranges and Cooktops))
by Daria 15 years ago
