I have a Magtag model number MGR6772BDS. The top oven will not bake or broil. I think it is the ignitors, but I dont want to replace both if I only need to replace one. Any answers?
I have the same problem. The bottom oven works fine as well as the burners. The display pad is working fine also. The ignitors in the top oven don't appear to be broken. Do I just turn the top oven on bake or broil and check ti see iif there is voltage going to them??
