Replacement parts for MAYTAG MDE6700AYW Dryer - Ele | AppliancePartsPros.comHere is a tech sheet and a manual and a bulletin which may apply
http://www.servicematters.com/m...ibrary/docs/16026881.pdf http://www.servicematters.com/m...ibrary/docs/16025911.pdf http://www.servicematters.com/m...rary/docs/TDL-0141-B.pdfI'm hoping someone can help me out the dryer goes through the regular cycle when I dry (spins and everything) except the clothes are still wet like if I never turned it on. I use the fluff cycle (a couple of times at 99 minutes) and the clothes get dry. I am assuming that if you run the unit for a couple 99 minute cycles the clothes will dry independent of cycle type though the above seems to indicate that the clothes will never dry on any cycle other than a Fluff which would be very weird.
My grandpa seems to think the heating element core without having seen it. Grandpa may be correct and since I have 5 grandchildren I just naturally feel I should side with him.
You could try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heater requires the full 240 volts.
If this does nothing I would check it at the plug
L1 to L2 should be 240 volts
L1 to Neutral and L2 to Neutral, both should be 120 volts
If OK
Try the diagnostics to see if it will help narrow the cause down.
If OK or inconclusive
Open the unit up and check the heating coil, should be approximately 10 ohms.
If OK
Check the thermostats in the heater circuit, all should be 0 ohms
If OK
Check the thermistor and the moisture sensor
If OK
Odds are high that the control board is shot.
