Maldonado316
#1 Posted : Thursday, December 3, 2009 2:48:49 PM(UTC)
Maldonado316
Hi! I'm hoping someone can help me out the dryer goes through the regular cycle when I dry (spins and everything) except the clothes are still wet like if I never turned it on. I use the fluff cycle (a couple of times at 99 minutes) and the clothes get dry. Any ideas? My grandpa seems to think the heating element core without having seen it.
Maytag Neptune
Purchased: February 2007
Model #: MDE6700AYW
#2 Posted : Friday, December 4, 2009 5:57:52 AM(UTC)
Replacement parts for MAYTAG MDE6700AYW Dryer - Ele | AppliancePartsPros.com
Here is a tech sheet and a manual and a bulletin which may apply
http://www.servicematters.com/m...ibrary/docs/16026881.pdf
http://www.servicematters.com/m...ibrary/docs/16025911.pdf
http://www.servicematters.com/m...rary/docs/TDL-0141-B.pdf
I am assuming that if you run the unit for a couple 99 minute cycles the clothes will dry independent of cycle type though the above seems to indicate that the clothes will never dry on any cycle other than a Fluff which would be very weird.
Grandpa may be correct and since I have 5 grandchildren I just naturally feel I should side with him.
You could try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heater requires the full 240 volts.
If this does nothing I would check it at the plug
L1 to L2 should be 240 volts
L1 to Neutral and L2 to Neutral, both should be 120 volts
If OK
Try the diagnostics to see if it will help narrow the cause down.
If OK or inconclusive
Open the unit up and check the heating coil, should be approximately 10 ohms.
If OK
Check the thermostats in the heater circuit, all should be 0 ohms
If OK
Check the thermistor and the moisture sensor
If OK
Odds are high that the control board is shot.
FixYa2
#3 Posted : Friday, December 4, 2009 11:59:44 AM(UTC)
FixYa2
Me too!
Friend took off plug-in wire back panel.(3)Wires.(2) "burned-a-part".(1) "burned" still slightly attached.(2) were what caused "heating".(1) wire caused "power to dryer", why it still runs and blows cold air!!! Repairman said "SIMPLY" the wires were not screwed on tight enough to back panel!!!
What do I do now? For $50.00 repairman will come out and look-see. Delima: (1) chuck $1,000 dryer, because many weeks delay?, wrong parts, try something else?, more money, moremoney, more money? -or- (2) Go get used $75 dryer and do laundry now!
:confused: FixYa2....
#4 Posted : Sunday, December 6, 2009 1:38:36 AM(UTC)
FixYa2
Please start your own thread using in this section "POST NEW TOPIC"
Hijacking another person's when you have a different problem and a different machine will just confuse things
thanks
Denman
Maldonado316
#5 Posted : Thursday, December 10, 2009 6:39:02 AM(UTC)
Maldonado316
Thanks for the reply denmen, i'll give those a try
