jsdorn
#1 Posted : Friday, March 7, 2008 9:13:31 AM(UTC)
jsdorn
I have a Bosch microwave that is 4 years old .The microwave stopped heating .I had a service person tell methe magnetron was bad,but never got back to me with a price i took the magnetron to another person and he told me the magnetron was ok he had I ohm across the terminal and there was no short from either terminal to the chassi.He suggested that the diaode was bad I replaced the diaode and have the same results.Could the magnetron still be bad with thoes readings and if so what else could be the problem ?Could the cap be bad i get a charge when I put power to it and short the terminals Every thing works on the microwave except no heat.The magnetron part number is 2M248J(GS).what does the GS represent.
roycreamer
#2 Posted : Friday, March 7, 2008 3:35:45 PM(UTC)
roycreamer
Groups: Expert
CAREFULLY see if you have 110 volts to the transformer terminals, DO NOT TOUCH ANY OTHER PART OF THE TRANSFORMER! if you do, replace the cap first, they're cheap. the mag next, it could still be bad.
Microwave fuse blows out frequently (Microwave Repair)
by Guest 6/15/2024 4:55:42 AM(UTC)
LG LMV1680ST Microwave Door Switches (Microwave Repair)
by ctalbert150 6/13/2024 7:19:37 AM(UTC)
Whirlpool Oven/Microwave combo E1 F2 (Oven Repair (including Ranges and Cooktops))
by MalcolmR 6/12/2024 10:02:00 AM(UTC)
Solved: Removing microwave unit from wall mounted Oven/Microwave combo (Oven Repair (including Ranges and Cooktops))
by MalikR 6/10/2024 3:04:18 PM(UTC)
Whirlpool Gold Accubake Oven/Microwave (Oven Repair (including Ranges and Cooktops))
by Guest 6/10/2024 10:21:28 AM(UTC)
How to pull microwave out of mw/oven combo (Oven Repair (including Ranges and Cooktops))
by cromking 5/6/2024 1:13:05 PM(UTC)
Microwave goes dead when hot (Microwave Repair)
by Guest 5/5/2024 8:05:15 AM(UTC)
Door Switch Help With Samsung Microwave Model ME21M706BAS (Microwave Repair)
by clagrow 5/2/2024 6:28:45 AM(UTC)
GE PT7800SHASS Combination Microwave / Oven - Key Panel SHORTED (Oven Repair (including Ranges and Cooktops))
by RCAppl 4/23/2024 7:59:18 AM(UTC)
GE Oven - Microwave/Oven PT7800SH2SSA (Oven Repair (including Ranges and Cooktops))
by Guest 2/13/2024 11:22:12 AM(UTC)
Kenmore Pizza Oven Microwave (Microwave Repair)
by mwjkmail 2/3/2024 5:10:49 PM(UTC)
Kitchenaid (Whirlpool) Microwave door switches (Microwave Repair)
by ForumUser1 1/11/2024 1:11:07 PM(UTC)
Whirlpool Microwave Lower Bulb will not turn on (WMH31017HS08) (Microwave Repair)
by Axtell 1/2/2024 3:49:44 PM(UTC)
Kitchen aid electric wall microwave and oven (Microwave Repair)
by Guest 11/9/2023 8:15:09 AM(UTC)
Frigidaire Microwave PLMVZ169HCA (Microwave Repair)
by Guest 10/25/2023 11:02:01 AM(UTC)
