The problem began with the oven, it would heat to temperature, but would not re-ignite to maintain the temperature.
Now it will not ignite at all, the ignitor glows but the burner will not light, there is no gas to the burner.
The ignitor still glows as long as the oven is turned on. There are no fault codes.
This is a propane range and was converted when it was installed, I have not had any problems with it until about 2 weeks ago.
