Triciav48
#1 Posted : Monday, June 29, 2015 6:36:33 AM(UTC)
Triciav48
My 5 year old Ikea Nutid wall oven (Whirlpool) like the rest on this forum had the oven door locked and no display after first time using self clean. I followed your instructions and replaced the thermal fuse and the thermal overload safety thermostat. The display panel now works, however the oven won't come on. Any sdvice?
Thanks,
Trish
#2 Posted : Monday, June 29, 2015 8:59:13 AM(UTC)
Parts for Whirlpool IBS550PWS00 Oven - AppliancePartsPros.com
Check that the oven thermal fuse is 0 ohms.
Check that the power to the unit is OK.
The oven elements require the full 240 volts.
Try flipping the breaker off/on slowly, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
File Attachment(s):
IBS550.pdf (1,534kb) downloaded 38 time(s).
