Whirlpool side by stopped working.Lights work,but fan, compressor don't.There is a constant clicking in the plastic box on side.Any help would be appreciated.Model #GS6SHEXML00.
Replacing the start relay will probably fix that problem
I would remove the back panel of the fridg. and check where the noise is coming from. If the compressor, you can try a new start device on the compressor, however GE start devices rarely fail. If it's coming from the pc board, it's probably bad. Order here AP4334000
Originally Posted by: Qtip  Replacing the start relay will probably fix that problem Thanks Qtip I read somewhere to shake the relay ,if it rattled it was bad.It doesn't rattle.I'm thinking it is probable the pc board,since the clicking is coming from there.Or not???? AGAIN THANKS FOR YOUR INPUT....
I would follow richappy's advice he knows much more than i do.
THIS FORUM IS DEAD!!!!!!! |
Thanks denman and richappy.The pc board did the trick.I ordered the part Monday afternoon got it Tuesday afternoon. Installed it Tue. evening and the cold air started flowing..Thanks again guys for the info It's very much appriciated.. Bigike
