bigike1971
#1 Posted : Saturday, November 28, 2009 7:13:31 PM(UTC)
bigike1971
Whirlpool side by stopped working.Lights work,but fan, compressor don't.There is a constant clicking in the plastic box on side.Any help would be appreciated.Model #GS6SHEXML00.
Qtip
#2 Posted : Saturday, November 28, 2009 7:26:04 PM(UTC)
Qtip
Replacing the start relay will probably fix that problem
#3 Posted : Sunday, November 29, 2009 2:46:43 AM(UTC)
I would remove the back panel of the fridg. and check where the noise is coming from. If the compressor, you can try a new start device on the compressor, however GE start devices rarely fail. If it's coming from the pc board, it's probably bad. Order here AP4334000
bigike1971
#4 Posted : Sunday, November 29, 2009 9:32:34 AM(UTC)
bigike1971
Thanks Qtip I read somewhere to shake the relay ,if it rattled it was bad.It doesn't rattle.I'm thinking it is probable the pc board,since the clicking is coming from there.Or not???? AGAIN THANKS FOR YOUR INPUT....
Qtip
#5 Posted : Sunday, November 29, 2009 10:54:35 AM(UTC)
Qtip
I would follow richappy's advice he knows much more than i do.
#6 Posted : Monday, November 30, 2009 1:05:26 AM(UTC)
Replacement parts for WHIRLPOOL GS6SHEXML00 Refrigerator | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/d...0Sheet%20-%202255955.pdf
Since both the the condenser/compressor fan and the compressor do not run odds are high that it is a problem with the control as they are wired in parallel.
OR
the fan also has a problem.
OR
the voltage is low to the compressor for some reason. If the unit has the capacitor, try running without it. Would be a good idea to measure the voltage across the fan.
Could be that you are stuck in a defrost cycle. If this is the case the evaporator fan will also be off.
Try running the diagnostics.
bigike1971
#7 Posted : Thursday, December 3, 2009 1:43:58 PM(UTC)
bigike1971
Thanks denman and richappy.The pc board did the trick.I ordered the part Monday afternoon got it Tuesday afternoon. Installed it Tue. evening and the cold air started flowing..Thanks again guys for the info It's very much appriciated.. Bigike
Guest (5)
Automatic water filter bypass - Whirlpool Refrigerator GD5SHAXLQ02 (Refrigerator & Freezer Repair)
by z-vap 2/28/2024 2:08:23 PM(UTC)
Whirlpool Refrigerator question (Dishwasher Repair)
by staffx4 1/9/2024 11:15:21 AM(UTC)
Whirlpool Refrigerator WSF26C2EXY02 (Refrigerator & Freezer Repair)
by DLanier 12/4/2023 5:06:34 AM(UTC)
Whirlpool Refrigerator Issue (Refrigerator & Freezer Repair)
by jrbentley 11/5/2023 1:04:02 PM(UTC)
Whirlpool Refrigerator Model WSF26C2EXF01 not making ice. (Refrigerator & Freezer Repair)
by agarcia5 8/26/2023 4:53:02 PM(UTC)
Whirlpool Refrigerator Model ED25TEXHW01 (Refrigerator & Freezer Repair)
by jammer48 8/18/2023 1:05:09 PM(UTC)
Whirlpool Refrigerator cooling intermittently or not cooling at all (Refrigerator & Freezer Repair)
by lsitnj 8/12/2023 3:39:26 PM(UTC)
Whirlpool Refrigerator inside lights, ice and water dispenser doesn't work (Refrigerator & Freezer Repair)
by Guest 1/6/2023 5:15:20 PM(UTC)
Whirlpool Refrigerator making a rather odd noise (Refrigerator & Freezer Repair)
by dbdata 12/7/2022 9:55:57 AM(UTC)
Whirlpool refrigerator water dispensing issue (Refrigerator & Freezer Repair)
by andymayor 7/6/2022 2:22:17 PM(UTC)
Whirlpool refrigerator replacement ice maker (Refrigerator & Freezer Repair)
by MELLIOTT 6/9/2022 9:06:52 AM(UTC)
Whirlpool refrigerator Model Number et1mtkxkq07 (Refrigerator & Freezer Repair)
by Guest 5/13/2022 1:16:28 AM(UTC)
Whirlpool refrigerator won’t freeze (Refrigerator & Freezer Repair)
by Nick72 5/12/2022 7:37:51 AM(UTC)
Whirlpool Refrigerator GD5SHAXLQ02 - Door not dispensing ice (Refrigerator & Freezer Repair)
by z-vap 3/21/2022 5:33:58 AM(UTC)
Whirlpool Refrigerator Freezer Coils Icing up (Refrigerator & Freezer Repair)
by aarrington 2/25/2022 5:39:48 AM(UTC)
