GE side by side GS22VGMD WW not maintain temps.
Freezer has ice on back wall - temps around 32-33 range. Fridge is around 48-50 degrees.
Compressor runs, evap fan runs.
I suspect defroster heater, defrost thermostat, or motherboard problem.
Anyone have the t/s manual and part numbers?
Procedures to test each part would also help. I assume I can do a continuity check on the heater and thermostat (when cold/near freezing temps). Anyway to check the motherboard?
Gene,
Manually defrosted coils and heater shows no continuity. I read bohemians comments about disassembling the heater - trying that now but will order new heater for $30 to ship friday. The manual defrost should get me through the holiday. Hope this solves this problem without having to order the mother board.
