chisum
#1 Posted : Sunday, March 2, 2008 12:50:27 PM(UTC)
chisum
My Whirlpool side by side refrigerator's ice maker stopped woring the other day. I have water going to the water dispenser, but the ice maker is producing any ice. What is the first step in determining what is wrong with my refrigerator. HELP!!!
#2 Posted : Monday, March 3, 2008 12:10:49 PM(UTC)
The first thing I would check is the water feeding tube into the ice maker for frost inside.
If it is frozen up, defrost it using a hair dryer and replace the water inlet valve (#10 on the ice maker parts break down diagram).
- The part number for the water inlet valve is AP3160649
Here are the break down diagrams for the Whirlpool refrigerator Model ED5FHEXMT00
chisum
#3 Posted : Monday, March 17, 2008 12:01:24 PM(UTC)
chisum
I checked the water feeding tube, no signs of frost or water. What now?
#4 Posted : Monday, March 17, 2008 12:21:14 PM(UTC)
You can find the complete troubleshooting instructions in on of previous posts: http://forum.appliancepartspros...-maker-quit-working.html.
Post your findings, please.
chisum
#5 Posted : Monday, March 17, 2008 5:37:40 PM(UTC)
chisum
Well after testing points L & N, there was 120V. I then created a short with points T & H, and the motor didn't respond. So I have to replace the entire unit, what is the part number and what is the cost range.
#6 Posted : Monday, March 17, 2008 6:04:35 PM(UTC)
There are two options:
1. You can replace the motor-module which cost $61.90
or
2. You can replace the whole ice maker which cost $96.50
Because we do not know what else, besides the motor, is bad - I would recommend to replace the whole ice maker.
- The part number for the motor-module assembly is AP3177342
- The part number for the ice maker is AP2984633
chisum
#7 Posted : Wednesday, March 19, 2008 10:15:27 PM(UTC)
chisum
Well I replaced the entire ice maker, and nothing happened. Will the ice maker automaticly start, or do I need to reset something? I don't know if the water is even getting to the freezer. I do have water coming from the door? And there are no signs of frost or freezing in the line coming through the back of the frigerator.
