Yes, with such designed microwaves you have to remove the outer case to access all parts inside.
Originally Posted by: Gene Yes, with such designed microwaves you have to remove the outer case to access all parts inside.
Gene. got it open and ordered the part. terrible plastic clip design, should be metal.
Good job! Keep us posted.
I cannot find the bit to remove the outer casing of the microwave. I have tried the Torx 15,20,25,27 and 30. None worked. Someone mentioned a hollow one? I did not see these. If so what size? Thanks
Per the information posted by jucs on the previous page, he got his as a kit from Home Depot.
I took a macro picture of the screw and showed it to tool dept at Home Depot. The Torx screw has hollow interior. HD had a set for $10-15 with many sizes.
