3 Pages<123
#21 Posted : Friday, February 10, 2012 4:19:53 PM(UTC)
Yes, with such designed microwaves you have to remove the outer case to access all parts inside.
equalizer
#22 Posted : Sunday, February 12, 2012 5:27:20 PM(UTC)
equalizer
got it open and ordered the part. terrible plastic clip design, should be metal.
#23 Posted : Monday, February 13, 2012 1:07:36 PM(UTC)
Good job! Keep us posted.
cluelessone
#24 Posted : Monday, June 11, 2012 12:44:58 PM(UTC)
cluelessone
I cannot find the bit to remove the outer casing of the microwave. I have tried the Torx 15,20,25,27 and 30. None worked. Someone mentioned a hollow one? I did not see these. If so what size?
#25 Posted : Monday, June 11, 2012 2:54:22 PM(UTC)
Per the information posted by jucs on the previous page, he got his as a kit from Home Depot.
equalizer
#26 Posted : Monday, June 11, 2012 5:40:35 PM(UTC)
equalizer
I took a macro picture of the screw and showed it to tool dept at Home Depot. The Torx screw has hollow interior. HD had a set for $10-15 with many sizes.
Guest (10)
Whirlpool microwave door will not open and microwave not working (Microwave Repair)
by bbowen 2/21/2009 6:50:20 PM(UTC)
3 Pages<123
