vance
#1 Posted : Wednesday, February 27, 2008 4:09:48 PM(UTC)
vance
The rod that is between the motor and the top of the motor is leaking.
How do I fix that?
Can I just replace the rod?
#2 Posted : Thursday, February 28, 2008 1:34:17 PM(UTC)
Most likely the water is coming out due to broken seals in the pump.
You can replace the seals on the old pump or replace the whole pump & motor assembly.
In both cases the dishwasher has to be removed from the cabinet.
- The part number for the impeller and seal kit is AP631386
- The part number for the pump & motor assembly is AP2616850
Both parts are coming with the installation instructions.
Here are the break down diagrams for the Hotpoint dishwasher Model HDA100X-66WH
Hotpoint dishwasher not working (Dishwasher Repair)
by Guest 7/25/2022 1:43:03 PM(UTC)
Older Hotpoint Dishwasher not Cleaning (Dishwasher Repair)
by Polly147 8/23/2015 3:04:31 PM(UTC)
Hotpoint Dishwasher (Dishwasher Repair)
by HunterChase 1/31/2014 1:11:52 PM(UTC)
Hotpoint Dishwasher leak (Dishwasher Repair)
by stranger12 12/23/2012 1:15:12 PM(UTC)
Hotpoint dishwasher leaking from bottom of motor (Dishwasher Repair)
by Beacon18 10/1/2012 10:45:36 AM(UTC)
HotPoint dishwasher stopped working (Dishwasher Repair)
by miklik 8/30/2012 12:18:10 PM(UTC)
hotpoint dishwasher (Dishwasher Repair)
by kleet2310 2/15/2012 2:03:19 PM(UTC)
by Robert Humphrey 12/29/2011 6:52:35 AM(UTC)
Hotpoint Dishwasher Timer Problem (Dishwasher Repair)
by james.hood@yahoo.com 2/13/2011 4:32:30 PM(UTC)
HotPoint Dishwasher draining intermittently (Dishwasher Repair)
by coomerguy08 2/12/2011 5:11:10 AM(UTC)
Hotpoint dishwasher won't drain (Dishwasher Repair)
by OneEye 1/18/2010 2:02:21 PM(UTC)
Older Hotpoint Dishwasher (Dishwasher Repair)
by benderra 1/15/2010 10:00:39 AM(UTC)
Hotpoint dishwasher not Draining (Dishwasher Repair)
by FoByFo 1/6/2010 4:59:00 PM(UTC)
Hotpoint Dishwasher HDA750S-45BA Drain Solenoid (Dishwasher Repair)
by tjones829 4/20/2009 6:13:45 PM(UTC)
Hotpoint Dishwasher Makes Buzzing Noise, Won't Drain (Dishwasher Repair)
by gwolfson75287 4/9/2009 8:12:26 AM(UTC)
