springmaster
#1 Posted : Saturday, November 14, 2009 8:49:47 AM(UTC)
springmaster
Just bought a house that included the stainless steel Kitchenaid appliances but none of the manuals so here I am ......
The interior lights have gone out and that was followed by a series of three quick beeps that go off every 5 minutes or so. I can see where the bulbs go but the plastic housing doesnt snap out and it appears that there are a couple of rivets holding the plastic cover in place. Cant seem to get a phillips or flathead screwedriver on them and very awkward to boot. Also noticed that the digital panel that shows the temp of the freezer, refrigerator and filter reading are also not lit.
I dont want to break the plastic cover by bending it back but I am kinda stuck,,,,, any advice would help
#2 Posted : Sunday, November 15, 2009 3:06:41 AM(UTC)
Following should fill your info needs to over flowing.
Replacement parts for WHIRLPOOL KSSP42QMS01 | AppliancePartsPros.com
Here is the operators manual
http://shared.whirlpoolc...0Guide%20-%202309068.pdf
Here are 3 tech sheets on the unit
http://www.servicematters.com/d...0Sheet%20-%202306332.pdf
http://www.servicematters.com/d...0Sheet%20-%202302865.pdf
http://www.servicematters.com/d...0Sheet%20-%202306424.pdf
And a service manual
https://secured.whirlpoo...75172/$FILE/4317326A.pdf
Looks like the items you are trying to undo are hex, you will need an allen keys set.
If they look like stars then they are actually referring to torx heads.
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
Kitchenaid Refrigerator Ice chute frosting up and clogging (Refrigerator & Freezer Repair)
by Guest 3/26/2024 9:05:12 AM(UTC)
Kitchenaid Refrigerator Issues With Dispensing Water (Refrigerator & Freezer Repair)
by Guest 10/2/2023 1:29:10 PM(UTC)
Kitchenaid Refrigerator Help Needed (Refrigerator & Freezer Repair)
by Guest 5/31/2022 3:40:02 PM(UTC)
KFIS29BBMS03 KitchenAid Refrigerator freezer only gets to 17 degrees, Fridge seems okay at 38 (Refrigerator & Freezer Repair)
by JCohen8008 6/28/2021 8:00:28 AM(UTC)
KSRS25IKBL03 KitchenAid Refrigerator stopped making ice - optics have been replaced (Refrigerator & Freezer Repair)
by Jfranks 12/5/2020 2:47:58 PM(UTC)
Kitchenaid refrigerator problems (Refrigerator & Freezer Repair)
by Kendug 8/12/2020 7:40:47 AM(UTC)
Help! Tech sheet lost for Kitchenaid refrigerator (Refrigerator & Freezer Repair)
by DANDKB 4/24/2020 11:38:19 PM(UTC)
Kitchenaid Refrigerator KSSSQTB00 (Refrigerator & Freezer Repair)
by Spearcatcher 12/18/2018 1:39:56 PM(UTC)
KitchenAid refrigerator ice chute replacement (Refrigerator & Freezer Repair)
by harrychou25 7/11/2018 1:44:23 AM(UTC)
kitchenaid refrigerator diagnostic mode (Refrigerator & Freezer Repair)
by oldfartsexpress 5/24/2018 5:29:43 PM(UTC)
Hinge repair on KitchenAid Refrigerator (KSSC42QTS00) (Refrigerator & Freezer Repair)
by clivedaw 1/5/2018 12:47:03 AM(UTC)
KitchenAid refrigerator did not work (Refrigerator & Freezer Repair)
by hhh123456 6/14/2017 1:58:45 AM(UTC)
Kitchenaid Refrigerator ice maker (Refrigerator & Freezer Repair)
by southerncooker7173 8/25/2016 11:01:00 AM(UTC)
KitchenAid refrigerator KSSC48QTS00 not dispensing water or producing ice (Refrigerator & Freezer Repair)
by Koolman10 6/25/2016 11:40:22 AM(UTC)
