My freezer had alot of frost in it. I unplugged it and defrosted it. It is no longer getting cold. What can I do?
Here are your parts Replacement parts for GIB GFU21M3AW1 | AppliancePartsPros.comFirst you have to determine is the compressor running? Is it warm and can you feelk it vibrating? If not Is there power at the plug. Turn the temperature control from one end to the other a couple times and then leave it at a central settin. |
THIS FORUM IS DEAD!!!!!!! |
