mcraegaelic
#1 Posted : Monday, November 9, 2009 4:45:30 PM(UTC)
mcraegaelic
Refridge. runs constantly. Power bill is killing my budget. Freezer and fridge always cold. Is there just a part to replace to correct this?
Need Help!!
#2 Posted : Tuesday, November 10, 2009 4:54:51 AM(UTC)
Replacement parts for WHIRLPOOL ET25DMXAW00 | AppliancePartsPros.com
If unit has done this from when it was new, it may just be the way it runs.
If not.
Check/clean your condenser coils under the fridge.
I remove the kick plate and rear cover, roll the fridge to an open door and blow it out with my compressor. A leaf blower also works. You can also use a long handled brush and a vacuum. Just be careful you do not want to break anything under there.
Clean/check the condenser fan.
Check your door seals.
Remove the evaporator cover from inside the freezer and check the coils.
If you just have a frost pattern that is patchy or only on one section of the coils it could be you are low on freon but it is not bad enough yet to affect the cooling.
Here is a link with good troubleshooting help
http://www.applianceaid.com/refrigerator.html
evaporator fan runs all the time in FF compartment (Refrigerator & Freezer Repair)
by Guest 8/17/2023 6:27:55 AM(UTC)
Window unit runs all the time (Heating, Ventilation, and Air Conditioning (HVAC))
by Wilber256 5/23/2019 4:52:48 PM(UTC)
bosch dishwasher drain pump runs all the time (Dishwasher Repair)
by jimmy.faulkner 12/31/2016 7:22:25 AM(UTC)
kenmore upright runs all the time (Refrigerator & Freezer Repair)
by rlh1104 6/8/2015 11:09:03 AM(UTC)
fan runs all the time!!! (Refrigerator & Freezer Repair)
by ak97 7/1/2014 2:01:55 PM(UTC)
by ak97 7/1/2014 1:30:19 PM(UTC)
Dryer runs all the time (Dryer Repair)
by jderenberger 3/19/2013 2:02:25 PM(UTC)
vent hood fan runs all the time (Dishwasher Repair)
by jhauge 9/11/2012 2:11:13 PM(UTC)
fridge runs all the time, seems like hours (Refrigerator & Freezer Repair)
by neo99 5/1/2012 4:22:21 PM(UTC)
LG WM2277 Drain Pump Runs All the time (Washer Repair)
by souljoe 2/10/2012 2:39:37 PM(UTC)
Refrigerator runs all the time (Refrigerator & Freezer Repair)
by stevepeotone 8/23/2011 5:50:00 AM(UTC)
Refridgerator runs all the time (Refrigerator & Freezer Repair)
by PSI 6/30/2011 8:28:55 PM(UTC)
Ice Dispenser/crusher runs all the time (Refrigerator & Freezer Repair)
by NavyVet 4/29/2011 10:04:26 AM(UTC)
refrigerator runs all the time (Refrigerator & Freezer Repair)
by fridgenewbie76 9/12/2010 7:39:21 AM(UTC)
Frige runs all the time but is cold and water coming out of the freezer (Refrigerator & Freezer Repair)
by Olady 8/2/2010 2:31:11 PM(UTC)
