Drum turns on but no heat. circuit breaker, fuse, vent pipe everything is ok. noticed heating element is not coming on. thinking of chnging it, want to know shoud I check the thermostat and cut of switch before I change the heating element?
Here are your parts Replacement parts for WHIRLPOOL LER8648PG0 | AppliancePartsPros.comHere is the wiring diagram http://www.servicematters.com/d...0Sheet%20-%203979703.pdf Drum turns on but no heat. circuit breaker, fuse, vent pipe everything is ok. Did you flip the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. Better yet check it with a meter to be sure you have 240 volts (L1 to L2) noticed heating element is not coming on. thinking of chnging it, want to know shoud I check the thermostat and cut of switch before I change the heating element? Usually on a heating element you can see the break. The thermal fuse for the heating element is the one on the heating assembly. The one on the blower kills power to the motor. If you do not own a meter, I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long. If it saves ordering one unnecessary part it has paid for itself and you end up owning a useful tool. Most places will not let you return electrical parts so if you order it, you own it. A couple things to watch when measuring ohms and continuity 1. Always remove power from the machine otherwise you could blow your meter. 2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path. 3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale's dynamic range. There is a good STICKY at the start of this forum about it's use. |
THIS FORUM IS DEAD!!!!!!! |
