I have a GE dryer that's not heating. I checked the element and thermal fuse. All good When I checked the thermistor I got 163.7k.I assuming that's to high. The numbers on it is T-105j 76j1hx0007. Which I can find that number. 134587700 is the only number I see when looking for the original one. The problem is, the prongs on it are wider then the T-105 thermistor. I need advice? Thanks
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
I tried looking up that part no. 134587700, that is a Frigidaire part. The only thermister I found for your model number was this... https://www.appliancepar...t-we4m550-ap5793568.htmlDoes it look like this one? https://www.searspartsdi...u0ut-0026-363/id-we4m550It might be a thermister problem or it might be a bad relay on the board or possibly a bad switch on the motor. I really don't know very much about this model and brand of dryer. I just volunteer some of my time to try and help if I can. This will sound redundant, but make sure you have 240 volts AC to the dryer. A lot of dryers will tumble and seem to be working while only having 120 volts to them. You need the full 240 to heat. I used to see it all the time on service calls.
Cafe Dishwasher little to no heat, not cleaning dishes well.
(Dishwasher Repair)
by Jtaylor20
8 months ago
Whirlpool double oven RBD305PVS02 no display, no heat, lights work
(Oven Repair (including Ranges and Cooktops))
by Guest
3 years ago
Dryer runs for 5 -15 mins, no heat, wont turn back on
(Dryer Repair)
by cavalry577
7 years ago
Spins, no heat, no ignitor glow - Whirlpool Estate gas dryer
(Dryer Repair)
by ithryn
9 years ago
No Heat, Continuity good!
(Dryer Repair)
by Hawaii Guy 808
10 years ago
No Heat, Fried Wires
(Dryer Repair)
by castertvs
10 years ago
dryer no heat, doesnt turn off
(Dryer Repair)
by dmh3355
10 years ago
No heat, timer not advancing on autosense
(Dryer Repair)
by fgaggia
10 years ago
No Heat, Timer Does Not Advance
(Dryer Repair)
by MRGETITFIXED
10 years ago
No heat, so tested thermostats, now dryer won't even start
(Dryer Repair)
by ccauthe
11 years ago
No Heat, Tested parts for Continuity
(Dryer Repair)
by crappyone
11 years ago
GE Dryer No Heat, Tumbles, Open Door and Light Goes Out
(Dryer Repair)
by essdiddy
11 years ago
Dryer--No heat, continuity tests ok...what next?
(Dryer Repair)
by davesharpe
11 years ago
Dryer cyles, no heat, trips circuit breaker leg
(Dryer Repair)
by kwillie
11 years ago
no heat, thermostats good
(Dryer Repair)
by deadchef
11 years ago
