I have a GE dryer that's not heating. I checked the element and thermal fuse. All good When I checked the thermistor I got 163.7k.I assuming that's to high. The numbers on it is T-105j 76j1hx0007. Which I can find that number. 134587700 is the only number I see when looking for the original one. The problem is, the prongs on it are wider then the T-105 thermistor. I need advice? Thanks
Groups: Expert
I tried looking up that part no. 134587700, that is a Frigidaire part. The only thermister I found for your model number was this... https://www.appliancepar...t-we4m550-ap5793568.htmlDoes it look like this one? https://www.searspartsdi...u0ut-0026-363/id-we4m550It might be a thermister problem or it might be a bad relay on the board or possibly a bad switch on the motor. I really don't know very much about this model and brand of dryer. I just volunteer some of my time to try and help if I can. This will sound redundant, but make sure you have 240 volts AC to the dryer. A lot of dryers will tumble and seem to be working while only having 120 volts to them. You need the full 240 to heat. I used to see it all the time on service calls.
Cafe Dishwasher little to no heat, not cleaning dishes well.
(Dishwasher Repair)
Belarus Jtaylor20
5/16/2024 10:15:38 AM(UTC)
Whirlpool double oven RBD305PVS02 no display, no heat, lights work
(Oven Repair (including Ranges and Cooktops))
by Guest
1/5/2022 7:05:37 AM(UTC)
Dryer runs for 5 -15 mins, no heat, wont turn back on
(Dryer Repair)
by cavalry577
12/4/2017 6:06:31 PM(UTC)
Spins, no heat, no ignitor glow - Whirlpool Estate gas dryer
(Dryer Repair)
by ithryn
6/30/2016 3:03:52 PM(UTC)
No Heat, Continuity good!
(Dryer Repair)
by Hawaii Guy 808
4/11/2015 4:57:28 PM(UTC)
No Heat, Fried Wires
(Dryer Repair)
by castertvs
10/7/2014 7:42:43 PM(UTC)
dryer no heat, doesnt turn off
(Dryer Repair)
by dmh3355
9/7/2014 4:43:13 AM(UTC)
No heat, timer not advancing on autosense
(Dryer Repair)
by fgaggia
9/5/2014 12:48:30 PM(UTC)
No Heat, Timer Does Not Advance
(Dryer Repair)
by MRGETITFIXED
8/27/2014 8:36:01 AM(UTC)
No heat, so tested thermostats, now dryer won't even start
(Dryer Repair)
by ccauthe
6/17/2014 4:26:40 AM(UTC)
No Heat, Tested parts for Continuity
(Dryer Repair)
by crappyone
3/17/2014 9:42:46 AM(UTC)
GE Dryer No Heat, Tumbles, Open Door and Light Goes Out
(Dryer Repair)
by essdiddy
1/11/2014 5:07:52 PM(UTC)
Dryer--No heat, continuity tests ok...what next?
(Dryer Repair)
by davesharpe
1/5/2014 12:48:28 PM(UTC)
Dryer cyles, no heat, trips circuit breaker leg
(Dryer Repair)
by kwillie
1/1/2014 3:07:19 PM(UTC)
no heat, thermostats good
(Dryer Repair)
by deadchef
12/26/2013 5:51:08 PM(UTC)
