Guest
#1 Posted : Wednesday, June 15, 2022 3:57:06 PM(UTC)
Guest
Rank: Guest
Groups:
United States
Hi!
I had an issue with the whirlpool top load direct drive LSR7300PQ0 washer not agitating so replaced the agitator dogs. The washer worked for a few loads then would fill with water and hum. Replaced drain pump and motor coupling but still would not work. Then replaced the clutch, the washer worked for half a cycle then had the same problem again. New agitator assembly, new drain pump, new clutch, new motor coupling, new hoses. All parts are installed correctly. Any suggestions?
Guest
#2 Posted : Wednesday, June 15, 2022 4:03:26 PM(UTC)
Guest
Rank: Guest
Groups:
United States
Oh, also replaced the lid switch and burnt connector to no avail
Guest
#3 Posted : Wednesday, June 15, 2022 4:09:28 PM(UTC)
Guest
Rank: Guest
Groups:
United States
