AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Whirlpool top load direct drive washer LSR7300PQ0
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Hi!
I had an issue with the whirlpool top load direct drive LSR7300PQ0 washer not agitating so replaced the agitator dogs. The washer worked for a few loads then would fill with water and hum. Replaced drain pump and motor coupling but still would not work. Then replaced the clutch, the washer worked for half a cycle then had the same problem again. New agitator assembly, new drain pump, new clutch, new motor coupling, new hoses. All parts are installed correctly. Any suggestions?
Rank: Guest
Oh, also replaced the lid switch and burnt connector to no avail
Rank: Guest
Washer Repair
