jmkitson
#1 Posted : Saturday, November 7, 2009 12:45:17 PM(UTC)
jmkitson
I just had my dishwasher apart to repair a motor bearing. Probably had a few more parts off than needed. When I reassembled, I am getting a water leak from the pressure switch. It did not seem to be a water tight fit when I put it back on. Is it supposed to be sealed with some type of glue or something?
#2 Posted : Sunday, November 8, 2009 3:03:34 AM(UTC)
No if it fails in the future you would not be able to get it off.
I hate the spring clamps often they will not reseal correctly unless you get it in it's original position. Sometimes not even then.
Where ever possible I replace them with a screw clamp.
Always a possibility that it now has a hairline crack/cut.
jmkitson
#3 Posted : Sunday, November 8, 2009 1:46:05 PM(UTC)
jmkitson
It is not leaking where the hose clamps on. It is leaking where the pressure switch or soil sensor fits on. That piece is held on by a screw. I guess I need a new pressure switch/soil sensor?
jmkitson
#4 Posted : Sunday, November 8, 2009 1:52:04 PM(UTC)
jmkitson
Check out this part. Part Details - WHIRLPOOL Switch, pressure, part number: AP3182693
Where that fits on the sump assembly is where it leaks, not the hose onto that piece.
Whirlpool Leaking Oil and Clothes Still Damp (Washer Repair)
by jeffceo 1/29/2017 5:03:34 PM(UTC)
Whirlpool leaking (Dishwasher Repair)
by WintonP 7/5/2016 4:48:32 PM(UTC)
Whirlpool leaking from Inlet Valve (Dishwasher Repair)
by dbayducks 2/8/2015 11:58:28 AM(UTC)
Whirlpool Leaking need part have Picture (Dishwasher Repair)
by Blakester117 5/9/2013 12:25:45 PM(UTC)
Whirlpool leaking water into fridge (Refrigerator & Freezer Repair)
by Renlord 10/25/2010 5:36:23 AM(UTC)
whirlpool leaking from bottom (Refrigerator & Freezer Repair)
by krg8411 8/30/2008 8:44:51 AM(UTC)
Whirlpool leaking fluid on floor (Washer Repair)
by idobelieve 8/14/2008 11:19:36 AM(UTC)
