I just had my dishwasher apart to repair a motor bearing. Probably had a few more parts off than needed. When I reassembled, I am getting a water leak from the pressure switch. It did not seem to be a water tight fit when I put it back on. Is it supposed to be sealed with some type of glue or something?
You have been a member since:: 2/29/2008(UTC) Posts: 19,638
Is it supposed to be sealed with some type of glue or something? No if it fails in the future you would not be able to get it off.
I hate the spring clamps often they will not reseal correctly unless you get it in it's original position. Sometimes not even then.
Where ever possible I replace them with a screw clamp.
Always a possibility that it now has a hairline crack/cut. |
THIS FORUM IS DEAD!!!!!!! |
It is not leaking where the hose clamps on. It is leaking where the pressure switch or soil sensor fits on. That piece is held on by a screw. I guess I need a new pressure switch/soil sensor?
