Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Just stopped making ice one day. Water pressure good. Fills with water fine but won't eject. The optics check out ok; steady red when ice bin detector is closed. Red light goes off when freezer door is closed. I thought it was the ice maker itself and replaced it, only to have the same problem with the new one. Edited by user Tuesday, December 21, 2021 3:03:14 PM(UTC)
| Reason: Not specified
Rank: Guest
Not much help here, is there?
With the water off, and the cycle running, it should try and first heat the tray and then the ejector fingers should rotate, is this happening?
Rank: Guest
Thank you for the reply. The fingers don't rotate after filling and freezing.
Rank: Guest
Rank: Guest
Well... that was anticlimactic.
Groups: Expert
Rank: Guest
Thanks, TG.
The sensor appears to be working as designed, but I'll run the jumper wire on the plug and see if it cycles.
Rank: Guest
Well... I jumped the pins on the sensor board, left it for 48 hours, and...
Nothing.
