Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Just stopped making ice one day. Water pressure good. Fills with water fine but won't eject. The optics check out ok; steady red when ice bin detector is closed. Red light goes off when freezer door is closed. I thought it was the ice maker itself and replaced it, only to have the same problem with the new one. Edited by user Tuesday, December 21, 2021 3:03:14 PM(UTC)
| Reason: Not specified
Rank: Guest
Not much help here, is there?
Groups ready for retrieval: Registered
With the water off, and the cycle running, it should try and first heat the tray and then the ejector fingers should rotate, is this happening?
Rank: Guest
Thank you for the reply. The fingers don't rotate after filling and freezing.
Rank: Guest
Rank: Guest
Well... that was anticlimactic.
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
Rank: Guest
Thanks, TG.
The sensor appears to be working as designed, but I'll run the jumper wire on the plug and see if it cycles.
Rank: Guest
Well... I jumped the pins on the sensor board, left it for 48 hours, and...
Nothing.
