2 Pages12>
Discombobulated
#1 Posted : Tuesday, December 21, 2021 1:57:17 PM(UTC)
Guest
Rank: Guest
Groups:
United States
Just stopped making ice one day.
Water pressure good. Fills with water fine but won't eject.
The optics check out ok; steady red when ice bin detector is closed. Red light goes off when freezer door is closed.
I thought it was the ice maker itself and replaced it, only to have the same problem with the new one.
Edited by user Tuesday, December 21, 2021 3:03:14 PM(UTC)  | Reason: Not specified
Guest
#2 Posted : Monday, December 27, 2021 3:19:34 PM(UTC)
Guest
Rank: Guest
Groups:
United States
Not much help here, is there?
cfaber
#3 Posted : Tuesday, December 28, 2021 7:08:41 AM(UTC)
cfaber
With the water off, and the cycle running, it should try and first heat the tray and then the ejector fingers should rotate, is this happening?
Discombobulated
#4 Posted : Wednesday, December 29, 2021 3:01:30 AM(UTC)
Guest
Rank: Guest
Groups:
United States
Thank you for the reply. The fingers don't rotate after filling and freezing.
cfaber
#5 Posted : Wednesday, December 29, 2021 7:33:41 AM(UTC)
cfaber
does the tray heat?
Discombobulated
#6 Posted : Thursday, December 30, 2021 3:01:31 AM(UTC)
Guest
Rank: Guest
Groups:
United States
Yes.
Discombobulated
#7 Posted : Monday, January 10, 2022 3:48:21 PM(UTC)
Guest
Rank: Guest
Groups:
United States
Well... that was anticlimactic.
ThatGuy
#8 Posted : Tuesday, January 11, 2022 8:15:49 AM(UTC)
ThatGuy
Groups: Expert
United States
If you have this ice maker and its mounted sideways, its harvest cycle is controlled by the sensor and board mounted on both sides.
https://www.appliancepar...irlpool-gc3shexnb03.html
Boards...
part 26
https://www.appliancepar...w10757851-ap5956767.html
There's a whole test thing that goes with these jerky little boards. I really don't like this system. jmho
They can be found elsewhere for a lot less money. Just saying. Watch the video. There are some helpful videos on youtube that explains the test procedure better than I can here.
Edited by user Tuesday, January 11, 2022 8:16:58 AM(UTC)  | Reason: Not specified
Discombobulated
#9 Posted : Thursday, January 13, 2022 6:11:26 PM(UTC)
Guest
Rank: Guest
Groups:
United States
Thanks, TG.
The sensor appears to be working as designed, but I'll run the jumper wire on the plug and see if it cycles.
Discombobulated
#10 Posted : Thursday, January 20, 2022 1:48:16 PM(UTC)
Guest
Rank: Guest
Groups:
United States
Well... I jumped the pins on the sensor board, left it for 48 hours, and...
Nothing.
2 Pages12>
