my electric dryer stops part way through the cycle. The dryer stops and the light goes out. The dial stops turning. When it cools down, I can restart it. I replaced the thermostat last year and everything worked well, but now the problem is back. I have cleaned the dust out and checked the vent for obstruction, but none was found.:)
I would replace all the thermostats and thermal fuse. Before you commit to the expense, though, pull them out (one at a time), and make sure there is no film or dirt build-up on them. This could cause them to register the temperature incorrectly.
I checked the thermostat for dust and guess what I found? Dust. I wiped it off and everything is perfect! You are a genious! Thanks for all your help.
Marie
Glad to help you save some money. Well done.
