Guest
#1 Posted : Tuesday, August 17, 2021 6:55:25 AM(UTC)
Guest
Rank: Guest
United States
Whirlpool Duet front load, model wfw9400su00.
Washing machine threw an f02 code before even starting to wash. I checked the drain trap which needed to be cleaned. Unplugged the washer for a few minutes and plugged back in. Same error, f02. I install a new drain pump. Unplugged the washer for a few minutes and plugged back in. Now an f22 code is showing. Unplugged the washer for about 10 minutes and plugged back in. Now the code is back to f02. Any suggestions on what to do or how to fix the problem?
Thanks,
Paul
Whirlpool Duet front load washer model WFW8300SW02 (Washer Repair)
by Guest 12/4/2023 8:39:10 AM(UTC)
Whirlpool Duet front load f02 and f22 codes (Dishwasher Repair)
by phestering 8/17/2021 7:08:19 AM(UTC)
Whirlpool Duet Front Load Washing Machine model # WFW97HEXL (Washer Repair)
by mercado_m_a 12/11/2019 6:16:06 PM(UTC)
whirlpool duet front loading washing maching (Washer Repair)
by tikiwil 9/15/2019 4:39:18 AM(UTC)
Whirlpool Duet front load washer leaking (Washer Repair)
by bobbijohahn 8/19/2016 2:00:17 PM(UTC)
whirlpool duet front load washer wont start (Washer Repair)
by kitp 3/13/2015 11:05:40 AM(UTC)
F11 Error Code on Whirlpool Duet Front Load Washer (Washer Repair)
by tdag 1/4/2015 7:53:29 PM(UTC)
Whirlpool Duet front load washer will not dispense liquid fabric softener (Washer Repair)
by 030Chris358 12/28/2014 8:11:49 AM(UTC)
Whirlpool Duet Front Loader with LF error code (Washer Repair)
by tmylett 12/27/2014 3:18:29 PM(UTC)
Whirlpool Duet front load washer won't spin (Washer Repair)
by DANLUDLOW 11/30/2014 4:20:12 PM(UTC)
Whirlpool Duet front loader help needed-no drain/pump comes on in wash cycle (Washer Repair)
by rdcleeann 10/1/2013 5:42:30 AM(UTC)
Whirlpool Duet front loading washer (Washer Repair)
by Randy Berg 9/16/2013 3:04:45 PM(UTC)
Whirlpool Duet front loader washer fills with water and stops F20 error (Washer Repair)
by DougN62 10/24/2012 3:55:35 AM(UTC)
Whirlpool Duet Front Loader (Washer Repair)
by RICK GENZEN 3/6/2012 6:29:13 AM(UTC)
Help! My whirlpool duet front load dryer stuck in sensor mode! (Dryer Repair)
by Sandy DiMascolo 2/26/2012 1:25:34 PM(UTC)
