phestering
#1 Posted : Tuesday, August 17, 2021 7:08:19 AM(UTC)
phestering
United States
Whirlpool Duet front load, model wfw9400su00.
Washing machine threw an f02 code before even starting to wash. I checked the drain trap which needed to be cleaned. Unplugged the washer for a few minutes and plugged back in. Same error, f02. I install a new drain pump. Unplugged the washer for a few minutes and plugged back in. Now an f22 code is showing. Unplugged the washer for about 10 minutes and plugged back in. Now the code is back to f02. Any suggestions on what to do or how to fix the problem?
Thanks,
Paul
