Ge monogram ZET 1S MSSS won’t hold oven temperature. It will go up to the set temp but then it doesn’t keep the temp even close to the set temp. Example: I set the oven to 400. It comes up to 400 but then in maybe 10 minutes it is down to 326. I tried to get SF mode to work to reset the thermostat but, following the instructions, the SF mode will not appear. The oven is 10 years old. Is it worth repairing?
