I as called to inspect a Bravos washer that was making noise in the agitation and would only spin on low speed. After removing the drive belt I found a great deal of rotational play in the main drum drive pulley. Any thought as to the cause? Is this a splutch issue? Is this a gearbox issue? Is this a drum issue?
