Joined: 1/18/2019(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: Houston
I as called to inspect a Bravos washer that was making noise in the agitation and would only spin on low speed. After removing the drive belt I found a great deal of rotational play in the main drum drive pulley. Any thought as to the cause? Is this a splutch issue? Is this a gearbox issue? Is this a drum issue?
