jdamudman
#1 Posted : Friday, January 18, 2019 8:04:15 AM(UTC)
jdamudman
United States
I as called to inspect a Bravos washer that was making noise in the agitation and would only spin on low speed.
After removing the drive belt I found a great deal of rotational play in the main drum drive pulley.
Any thought as to the cause?
Is this a splutch issue?
Is this a gearbox issue?
Is this a drum issue?
