Differ
#1 Posted : Tuesday, July 31, 2018 11:52:11 AM(UTC)
Differ
Hello to all,
I have a Kenmore Laundry Center that is leaking at what I suspect is the tub seal. After one repair tech and Sears saying they will not repair something that is disassembled, I'm at a loss as to how to remove the plate that holds the motor and transmission. According to the manual, not the service manual, just remove the screws holding it to the outer tub and lift off. The tub nut has been removed. I've tried prying it off the tub, beating the shaft from inside the tub and still it will not budge. Is there a special tool I need or something else holding the inner tub to the shaft that isn't described in my paperwork?
Kenmore laundry center (Dryer Repair)
by waltjski 2/11/2013 12:30:45 PM(UTC)
Electric Dryer on Kenmore Laundry Center won't heat (Dryer Repair)
by JimKl 6/6/2012 7:17:15 PM(UTC)
Kenmore Laundry Center (Dryer Repair)
by Katy Wood 10/4/2010 10:06:58 PM(UTC)
Kenmore Laundry Center 417.99570100 (Dryer Repair)
by WRD0225 8/27/2010 8:00:55 AM(UTC)
kenmore laundry center wobbles (Washer Repair)
by gregdcwirth 3/16/2010 12:39:42 PM(UTC)
Smoking & No spin Kenmore Laundry Center (Washer Repair)
by torino1973 8/26/2009 3:53:08 PM(UTC)
Kenmore Laundry Center Dryer repair (Dryer Repair)
by Lovsexy4 2/11/2009 4:31:42 AM(UTC)
Kenmore laundry center dryer repair (Dryer Repair)
by Lovsexy4 2/9/2009 8:25:30 AM(UTC)
Kenmore Laundry Center drum not aligned and clothes getting stuck in gap (Dryer Repair)
by cmdoan81 11/19/2008 8:37:51 AM(UTC)
Kenmore laundry center (Washer Repair)
by loganski 9/7/2008 3:33:11 PM(UTC)
kenmore laundry center thermal limiter (Dryer Repair)
by sunshine5500 1/15/2008 10:58:11 AM(UTC)
Kenmore Laundry Center - Washer Clutch Question... (Washer Repair)
by ascdesigns 1/2/2008 7:32:58 AM(UTC)
