machine will agitate on each and all settings w/o filling with water. suggestions?
Hello ozarkhillbilly2, This is normally caused by an issue with the temperature switch [AP6017747]. It is also called an automatic load sensing switch and has a small control board inside that commonly causes this complaint.
