pjs-54
#1 Posted : Wednesday, November 4, 2009 2:15:10 PM(UTC)
pjs-54
Dryer works fine but makes a loud noise when turning
#2 Posted : Thursday, November 5, 2009 2:10:25 AM(UTC)
Replacement parts for WHIRLPOOL GEW9200LW2 | AppliancePartsPros.com
Here is a manual
https://secured.whirlpoo...64beaa/$FILE/Duetdry.pdf
A lot depends on what kind of noise it is.
Often a scraping noise is something caught between the drum and the frame.
Run your fingers around the back and front of the drum seals to see if something is caught in between (under-wire bra wires are famous for this)
Be careful in case it is sharp.
Thumping is often the rear support rollers.
Could also be the front supports, the motor bearings, the idler wheel, something in the blower, a loose blower etc.
Whirlpool Duet dryer WGD9400 knob Removal (Washer Repair)
by Guest 1/1/2023 8:41:47 AM(UTC)
Whirlpool Duet Dryer Drum turning difficulty (Dryer Repair)
by DWMalcolm 2/6/2022 12:41:34 PM(UTC)
Whirlpool duet dryer issue (Dryer Repair)
by Wes13 12/15/2021 3:54:09 PM(UTC)
Duet Mod# GE9200LW1 Whirlpool Duet dryer (Dryer Repair)
by Guest 11/17/2021 6:59:07 PM(UTC)
Whirlpool duet dryer making clicking noise (Dryer Repair)
by Ctiong916 4/23/2021 9:00:11 PM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
Whirlpool Duet Dryer - WED9200SQ0 - Thermal Fuse (Dryer Repair)
by cjmatthes 1/17/2020 2:09:48 PM(UTC)
Whirlpool Duet dryer - no heat (Dryer Repair)
by colino 3/19/2018 10:56:53 AM(UTC)
Whirlpool Duet Dryer Squeaks / Squeals (Dryer Repair)
by RickG375 1/5/2017 7:08:55 PM(UTC)
Whirlpool Duet Dryer Squeaks/Squeals At Start Up (Dryer Repair)
by damianr418 11/5/2016 6:53:54 PM(UTC)
Whirlpool Duet Dryer Grinding Sound (Dryer Repair)
by mintken 10/16/2016 8:31:42 AM(UTC)
Whirlpool Duet Dryer won't start (Dryer Repair)
by berthettah 7/21/2016 10:10:39 AM(UTC)
Whirlpool duet dryer (Dryer Repair)
by norbreym28 7/16/2016 8:29:04 AM(UTC)
Whirlpool Duet Dryer F02 and F70 codes (Dryer Repair)
by esnyder 7/6/2016 1:18:43 PM(UTC)
Whirlpool Duet Dryer Error Code f25 (Dryer Repair)
by wwwhitley 10/30/2015 12:09:40 PM(UTC)
