Ginadrc
#1 Posted : Friday, January 26, 2018 7:24:30 PM(UTC)
Ginadrc
I have a Kenmore dryer that will not start. The control panel is working and when the door is open I can hold the door switch in and touch start which will start the dryer. However, when the door is closed it will not start. I replaced the door latch and door strike hoping that would help but it did not. Any suggestions?
ThatGuy
#2 Posted : Friday, January 26, 2018 10:15:25 PM(UTC)
ThatGuy
Groups: Expert
United States
Ginadrc
#3 Posted : Saturday, January 27, 2018 7:14:52 AM(UTC)
Ginadrc
We didn't replace it because we can start the dryer by engaging the switch manually (holding it in with a finger and it clicks normally)and pushing start with the door open. Once we close the door it won't start.
ThatGuy
#4 Posted : Saturday, January 27, 2018 9:09:37 AM(UTC)
ThatGuy
Groups: Expert
United States
Okay, lets try this.
If you slowly close the door, do you hear the switch click at any time?
A switch like that can change where it activates as the lever is depressed. its broken or damaged internally. So closing the door doesn't activate it, but pushing it a little farther does. You probably need a new switch.
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 8/8/2021 1:55:18 PM(UTC)
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 11/7/2020 4:44:16 PM(UTC)
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Dryer won't start (Dryer Repair)
by Petem 12/2/2017 3:27:50 PM(UTC)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 6/8/2017 6:45:42 PM(UTC)
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 6/5/2017 9:20:31 AM(UTC)
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 3/13/2017 7:15:55 PM(UTC)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
Dryer won't start all the time (Dryer Repair)
by DaHadster 1/10/2017 12:25:28 PM(UTC)
