Ginadrc
#1 Posted : 7 years ago
Ginadrc
I have a Kenmore dryer that will not start. The control panel is working and when the door is open I can hold the door switch in and touch start which will start the dryer. However, when the door is closed it will not start. I replaced the door latch and door strike hoping that would help but it did not. Any suggestions?
ThatGuy
#2 Posted : 7 years ago
ThatGuy
Groups: Expert
United States
Ginadrc
#3 Posted : 7 years ago
Ginadrc
We didn't replace it because we can start the dryer by engaging the switch manually (holding it in with a finger and it clicks normally)and pushing start with the door open. Once we close the door it won't start.
ThatGuy
#4 Posted : 7 years ago
ThatGuy
Groups: Expert
United States
Okay, lets try this.
If you slowly close the door, do you hear the switch click at any time?
A switch like that can change where it activates as the lever is depressed. its broken or damaged internally. So closing the door doesn't activate it, but pushing it a little farther does. You probably need a new switch.
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 10 months ago
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest about a year ago
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 2 years ago
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 4 years ago
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 4 years ago
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 7 years ago
Dryer won't start (Dryer Repair)
by Petem 7 years ago
Maytag dryer won't start (Dryer Repair)
by eagle243 7 years ago
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 8 years ago
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 8 years ago
Inglis dryer won't start (Dryer Repair)
by jkeefe 8 years ago
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 8 years ago
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 8 years ago
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 8 years ago
Dryer won't start all the time (Dryer Repair)
by DaHadster 8 years ago
