scorpio012
#1 Posted : Sunday, January 21, 2018 12:45:44 PM(UTC)
scorpio012
Hello, My Dad recently passed away and he had what I believe was a Kenmore Washer and I'm sure it's a Kenmore dryer. The dryer wouldn't heat at all. It would run but no heat so I automatically thought it was the element. So I took the back panel off and the element looked fine and I went ahead and checked continuity and it was okay. Not being an appliance guy I wasn't sure what to check next and a friend of mine said to check the thermal fuse which I did with continuity and it was okay, but now i have no idea where to go next to check? I was hoping that someone here could direct me to a next possible part to check? Also, does anyone happen to know if there are any part location diagrams available for that model dryer? It would be a big help. Thanks for any possible help you can give me as I'd hate to throw the dryer away if it''s only going to take a $20 part to get it running again.
ThatGuy
#2 Posted : Sunday, January 21, 2018 2:38:50 PM(UTC)
ThatGuy
Groups: Expert
United States
First thing I always do is make sure there is 240 volts to the dryer and that the terminals and cord are OK. Once you've done that, you can start checking other things.
You check the element for continuity and you check the thermal fuse/cutout and the high limit thermostat on the side of the element.
If they are OK, check the thermostat located on the back of the blower housing. I usually check the thermal fuse at the same time.
If they are OK, I check the Timer for continuity when set on a heat cycle. If it tests good I usually end up doing a live voltage check to see where the voltage is stopped at. Most cases this isn't necessary.
If you go to $ears and type in your model number it will show you a parts diagram for your dryer. For some reason your model no. doesn't come up on this web site.
Oh, and if there is a heat selection switch they sometimes go bad and the switch on the motor can go bad to or burn a wire off. I hope this helps.
Kenmore Electric Dryer 110.65132411 (Dryer Repair)
by Guest 5/1/2024 5:58:30 AM(UTC)
Kenmore electric dryer model 110.68622700 (Dryer Repair)
by Guest 11/12/2023 6:47:37 PM(UTC)
Kenmore electric dryer won't stay running (Dryer Repair)
by steve37887 10/25/2019 4:52:25 AM(UTC)
Kenmore Electric Dryer Won't Heat (Dryer Repair)
by ginakra 9/21/2017 11:03:29 AM(UTC)
Kenmore electric dryer (Dryer Repair)
by carpenter83 12/1/2016 3:23:22 PM(UTC)
Kenmore Electric Dryer (Dryer Repair)
by johnhb 9/30/2015 7:27:45 AM(UTC)
by johnhb 9/30/2015 7:27:43 AM(UTC)
Kenmore Electric Dryer Won't power up. (Dryer Repair)
by lamarc72 11/19/2013 9:30:31 AM(UTC)
Kenmore Electric Dryer Runs and No Heat (Dryer Repair)
by dadunn1960 3/15/2013 8:14:52 AM(UTC)
Kenmore Electric Dryer - drum hits the top of the dryer. (Dryer Repair)
by willow5000 2/14/2013 9:19:06 PM(UTC)
Kenmore Electric Dryer - Runs but no heat and timer not running (Dryer Repair)
by CapN 12/11/2012 5:31:31 AM(UTC)
Kenmore Electric Dryer cuts off after running 2/3 minutes (Dryer Repair)
by Robert Ferrell 10/14/2011 9:21:09 AM(UTC)
Kenmore ELectric dryer (Dryer Repair)
by Donnadryer 9/11/2011 3:56:16 PM(UTC)
Kenmore electric dryer starts and stops (Dryer Repair)
by missfixit1974 9/9/2011 12:59:29 PM(UTC)
Kenmore electric Dryer won't Tumble (Dryer Repair)
by ohmydryer 9/6/2011 2:09:46 PM(UTC)
