Ok, so here's what's going on:
The washer won't spin or agitate. The motor control board gave me 7 flashes, indicating an open lid switch. I bypassed it with a wire nut, and it worked for one cycle. Same thing again. This time I crimped it, and it worked for one cycle. Same thing again. I verified the circuit was closed, but still had the same 7 flashes, so I replaced the motor assembly, as the tech sheet instructed. It worked for one cycle, and now the same thing again.
Anybody got any ideas? Thanks.
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
Replace the lid switch as not only does it detect the lid closed but must also detect the lid being opened after each load.... or it will give you a fault code.
