How do I remove the control panel. All video I find show this model with a raised panel accessed by removing to screws for further removal. The top on my dryer is completely flat.
There are 2 possibilities, there may be screws around the back edge of the top panel or a screw under the knob. I'm not sure off the top of my head. If there are no screws holding the top panel on on the back edge, gently pull the knob straight off and there is a long screw under it. The control panel then slides up and off.
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
PNWDrew, thank you so much for the information I couldn’t figure it out, screw is under the knob 😊
Joined: 10/10/2023(UTC) Posts: 0  Location: New Jersey
Originally Posted by: Guest  PNWDrew, thank you so much for the information I couldn’t figure it out, screw is under the knob 😊 Wow, you must be at peace now, Edited by user Wednesday, October 11, 2023 5:42:58 PM(UTC)
| Reason: Not specified
