I need to replace my INLET Water Valve on my GE Washer, Model # WPRB8050D1WW. I purchased the part from you yesterday and am having trouble removing the CONTROL Panel. Are there any instructions, suggestions, etc to assit me in removing it? Once I get it removed, I will be able to install the VALVE. Thanks..
Darn I don't have one of these in front of me but see if the back of the control panel doesn't come off and give you access to the water valve assembly.
Thanks for your reply. After the screws are removed from the back, I discovered the panel folds down, which allowed me room to replace the water inlet valve.
Great, glad you were able to get to it. Thanks for the update too.
