jimmyfoddrell@tds.net
#1 Posted : Wednesday, April 11, 2012 5:09:13 AM(UTC)
I need to replace my INLET Water Valve on my GE Washer, Model # WPRB8050D1WW. I purchased the part from you yesterday and am having trouble removing the CONTROL Panel. Are there any instructions, suggestions, etc to assit me in removing it? Once I get it removed, I will be able to install the VALVE. Thanks..
sidfink43
#2 Posted : Friday, April 13, 2012 12:40:23 PM(UTC)
sidfink43
Darn I don't have one of these in front of me but see if the back of the control panel doesn't come off and give you access to the water valve assembly.
#3 Posted : Friday, April 13, 2012 1:21:36 PM(UTC)
Thanks for your reply. After the screws are removed from the back, I discovered the panel folds down, which allowed me room to replace the water inlet valve.
sidfink43
#4 Posted : Friday, April 13, 2012 2:41:05 PM(UTC)
sidfink43
Great, glad you were able to get to it. Thanks for the update too.
