je00409
#1 Posted : Tuesday, September 5, 2017 11:00:04 AM(UTC)
je00409
Entered the test mode and got the following error messages:
Er:20 Spin Cycle Terminated, No communication between control and inverter, Unbalance too high, check wire harness, check load
dr:08 Speedometer Failure, Damaged speedometer, check wire harness
dr:10 Power limiter switch off, too heavy load, mechanical friction, check oscillating system, check gasket, check load
dr:11 Voltage too low, weak power supply, check line voltage
Given the above, is this something that can be repaired and if so, what parts are needed?
Thank you
missie
#2 Posted : Sunday, March 18, 2018 11:09:35 PM(UTC)
missie
I have the exact same model and mine won't spin at all. Only error code is E20. SOOO frustrated!!!
je00409
#3 Posted : Monday, March 19, 2018 3:38:10 AM(UTC)
je00409
It needed a motor and motor control board. I bought a new washer.
missie
#4 Posted : Monday, March 19, 2018 4:46:59 AM(UTC)
missie
Thanks so much for the quick reply! I THINK my motor is ok- if I tested it correctly... so I guess I'll gamble on the control board. Thanks, again!
3 year old top loading washer won't spin clothes dry (Washer Repair)
by craig100 3/15/2024 9:35:49 AM(UTC)
Samsung washer won't spin (Washer Repair)
by Guest 1/8/2022 10:56:39 AM(UTC)
Maytag Washer won't spin or complete cycle - FIXED! (Washer Repair)
by jimjokjv 10/1/2021 10:08:04 AM(UTC)
Whirlpool WTW4815EW1 Washer Won't Spin or Agitate (Washer Repair)
by dann1551 4/7/2021 8:42:00 AM(UTC)
Maytag performa washer won't spin. It drains and i can hear the motor but tub appears stuck. (Washer Repair)
by Brittrepairs 12/21/2019 7:47:28 PM(UTC)
Whirlpool LSN2000LW Washer Won't Spin, Buzzes (Washer Repair)
by Robb235 2/21/2019 4:21:02 AM(UTC)
Washer won't spin out. (Washer Repair)
by DJChad818 10/26/2017 9:47:20 AM(UTC)
Washer won't spin (Washer Repair)
by Fingers123 10/22/2017 1:43:41 PM(UTC)
Washer won't spin or agitate (Washer Repair)
by dhughes 4/1/2017 10:17:04 AM(UTC)
Whirlpool belt drive washer won't spin. (Washer Repair)
by weswoodallz21 3/21/2017 7:08:08 AM(UTC)
Maytag Washer won't Spin just Hums (Washer Repair)
by bnweth 1/4/2017 8:29:35 PM(UTC)
Whirlpool washer won't spin or drain (Washer Repair)
by ronaldjp1 1/3/2017 2:58:09 PM(UTC)
maytag washer won't spin fast (Washer Repair)
by benp1 12/21/2016 5:14:31 PM(UTC)
by lmhansgen 8/31/2016 10:19:23 AM(UTC)
Whirlpool Washer Won't Spin, Drain or Agitate (Washer Repair)
by dsagun 8/10/2016 5:19:50 AM(UTC)
