Godseekers@outlook.com
#1 Posted : Friday, June 30, 2017 1:13:11 PM(UTC)
Front load washer. Lately it won't stop spinning in final cycle unless i manually stop it. I found a diagnostic manual online and went through all the tests. There are no error codes listed, everything else works fine. I found several topics for similar issues and replacing the timer was the recommendation. Looking for any help you cab offer.
Washer won't stop spinning when it should (Washer Repair)
by Jpregler 2/6/2017 7:28:07 PM(UTC)
washer won't stop spinning (Washer Repair)
by GEturkey 1/31/2014 6:49:28 PM(UTC)
Washer won't stop spinning when opened (Washer Repair)
by lostic 10/16/2011 7:16:59 PM(UTC)
Kenmore washer won't stop spinning (Washer Repair)
by leinoffs 8/14/2008 12:08:50 PM(UTC)
